Parts upgrades required for a high-hp 4l60e above the usual street/strip 4l60e
Ive had one of our "street/strip" 4l60e's in my wifes 10 sec SS. With the new D1sc/fmic setup on the car, I sold the complete 4l60e/converter setup out of the car to a friend was going to follow the typical TH350/400 swap that ive done many of for the car to live at the 600-700 rwhp level the car is at.
I dont build my own trannies, a good friend of mine owns a local transmission shop and builds what ever I need for just cost of parts...He is putting the best parts he knows of in the tranny now, but im looking to add some more that I see in the FLT/Performa/RPM race 4l60's....
So far have had great luck with no problems at the 500-550 rwhp level with our current 4l60e's but im looking to go with some additional upgrades of hard parts over what we normally do.
Heres what parts I use now in a typical build (copy/past typical setup from one of the vendors sites):
# 8 B/W hi-energy clutches w/koleen steels in 3-4 clutch
# Seal & gasket kit
# Bushing kit
# Alto wide 2-4 red lined band with reinforced anchor
# Bonded pistons/input drum
# Beast sun shell
# B/W 29 element sprag
# 4L65 low roller clutch
# Transgo HD-2 shift kit
# Corvette servo
# New solenoids
# New internal wiring harness
# New GM Spacer plate
# B/W clutches
# Updated aluminum accumulator pistons
# prepped valvebody
# Filter
# Set end play to specs
# Install new cooler fittings
# Deep alum pan
Parts im looking to upgrade to :
5-pinion front/rear planets
Billet 4th gear Servo
Anyone have any input in the need of these parts, not sure what need they are exactly:
1) sleeved input drum
2) Bearing style reaction shaft
3) What level is a 300m output/input shaft needed, ive never broken one:
any other upgrades?
# Seal & gasket kit
# Bushing kit
# Beast sun shell
# Corvette servo
# New solenoids
# B/W clutches
# prepped valvebody
# Filter
# Deep alum pan
any other upgrades?
