What kind of tranny oil should i use??
Old 05-06-2009, 11:35 AM
zz28Junior's Avatar
Default What kind of tranny oil should i use??
I have a 2000 z28 camaro and its a a4 and i need to change the oil on it just wanting to know which kind of oil should i use any help woild be great thanks
Old 05-06-2009, 11:44 AM
Breathing Fire's Avatar
Amsoil atf. However that may be a little slick. Thats what I use but im M6.
Old 05-06-2009, 01:03 PM
01ssreda4's Avatar
just use the castrol atf or whatever they got in the auto parts place. just make sure its for GM.
Old 05-06-2009, 01:20 PM
355z28's Avatar
I wonder what the deal is with all these guys running just type F in them? theres a couple builders here in town that run that in there performance trannys. They all seem to hold up, just dont know if I would do that in mine.
Old 05-06-2009, 01:34 PM
FiFdYnUtz's Avatar
i heard synthetics are hard on high stalls...not sure if thats true though
Old 05-06-2009, 09:06 PM
tording99Z28's Avatar
I just run standard Castarol Dextron III fluid that is made for older domestic cars. I get it at autozone for like $3.00 a quart.
Old 05-06-2009, 09:11 PM
jsteele90's Avatar
regular dex 3 is all u need nothing fancy
Old 05-07-2009, 05:53 PM
RoDan's Avatar
yep, non synthetic dex III. I ran RP atf, and I swear it was too slick and caused premature clutch failure. The clutches wouldn't hold. With this tranny, I'm running Valvoline ATF.
