cracked flexplate
Old 05-09-2009, 07:56 PM
C5042081's Avatar
Default cracked flexplate
I dont have much of a noise, would a cracked flexplate cause vibration when I touch the shifter? I also notice vibration thru out the rpms of and on when in park.
Trans mount and motor mounts are new
Old 05-09-2009, 08:08 PM
LS1Tech Sponsor
performabuilt's Avatar
Could be but you said you have new engine and trans mounts they would not happen to be poly mounts would they ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-09-2009, 08:59 PM
C5042081's Avatar
yes both are poly, but the shaking happened before i put them in,
i noticed it after breakin on the stall, the first time I nailed it off the start then the shaking/ vibration started
Old 05-09-2009, 10:15 PM
LS1Tech Sponsor
Well I will say poly mounts do indeed transfer alot of vibration.
__________________
Call 888-744-6542
