Torque Converter Confusion
1 Post
Ok... so I guess I am confused about torque converters. I installed a 2800 torque converter on my '95 Z last week. When I am "flashing" the stall, the highest I can get up to is 2100 before the car starts brake rolling. What is the highest the car should get up before it starts to brakeroll?
Thanks!
Thanks!
LS1Tech Sponsor
It seems pretty much to normal. It also depends on wich stator was used and how well you brakes are.
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
Thanks!
Thanks!
Flash stall is nailing it from a stop or such, no brakes.
Brake stall is what your doing by holding the car in place and gassing it. Like mentioned internals of the verter, power and brakes will decide that for you.
Example; My Circle D flashes to 4,200 but I can only get it up to 2,500 on the brakes before they cant hold it back any longer.
1 Post
Yeah... a couple guys mentioned check my brakes. I changed them in August and maybe put 1000 miles on them since so... I can't imagine that they are screwed up. Although I did take it to the track a couple of times since then
I guess what I need to realize is that the power band in the car has moved. The car seems sluggish in everyday driving situations. At 30-rolls, the car doesn't go like it used to (we all know how good 30-rolls are in these cars), but at 45 mph the car goes pretty good. I just have to get used to the changes. Next... 17x11s, 315 DRs, and a gear!
