anyone rebuild a 4l60E themselves?
Old 05-21-2009, 08:48 PM
nastychevelle's Avatar
Default anyone rebuild a 4l60E themselves?
was it very hard? will it be somewhat easy if im mechanically inclined?
will this be sufficient for a 97 4l60e that has lost reverse and 3rd? and will this be able to support decent HP (i only need it to support around 360rwhp right now but plan to go to a turbo setup in the future with around 600-700RWHP)?
the kit includes (multiple parts i selected)
complete Transtec gasket and seal kit
American made Alto clutches and band (will be using RED parts listed below)
Federal Mogal or Clevite front and rear case bushings
Sealed Power full ring kit and filter
ALTO RED EAGLE HIGH PERFORMANCE EXTRA WIDE BAND
ALTO 3-4 update Red Eagle High Performance Kit with
7 ALTO RED EAGLE .062" FRICTIONS
6 KOLENE .106" STEELS
how much HP could this handle?
Old 05-21-2009, 08:55 PM
Circle-D's Avatar
My suggestion is do it only because you want to, a challenge. Don't do it because you are trying to save money, it will probably cost more if you factor in your time and the possibility of having to pull it out because of a problem. There are some DVD's and books that will help out. I have a rebuild kit on my website that is a good list to go by.
Chris
Old 05-21-2009, 09:03 PM
LS1Tech Sponsor
performabuilt's Avatar
I would agree with Chris , If you want to do it as a challenge or just to learn , Great! If you are doing it to save money or if you need the car regulary. Probably a risky idea.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-21-2009, 09:23 PM
well i want a challenge as well as trying to learn and have a while to do it (still need parts for 5.3 swap most likely going in around the end of summer)
is there anything else that you guys would recommend i pick up? it will be getting a shift kit and cooler also and most likely a deep pan
what kind of HP would a build with these parts be able to handle?
Old 05-21-2009, 09:31 PM
VortecHOjunkie's Avatar
Its tricky getting the return springs compressed. Not too bad other than that. Make sure you have a manual and get the specs right.
Old 05-21-2009, 09:34 PM
yah i definitely planned on getting a manual!
Old 05-21-2009, 10:47 PM
PedaltoMetal's Avatar
Yes, only do it if you want a challenge. For me everybody I know knew everything about an engine, but got scared when the transmission started acting up. So I wanted to see what was so "scary" about them. I started collecting factory service manuals, fluid diagrams, hydraulic systems, principles of operation, etc. They became the morning newspaper for me. The first one I did I didn't set the 3/4 clutches up right and burned em up. It's a apart in my garage right now. The 2nd has a year on it now as I drive it everyday. It's in a 4x4 that also sees offroad use. Other than a weird lock-up issue, I've had no problems. The third I just finished for my 95 Camaro Z. I went all out on it and I mean all out. This time I got everything perfect. Even put a TCI converter in it.
I tell ya, WOT pulls with a good stall will put a smile on your face every time. Only problem is now I need better traction. So after all that, I could do another one without the manuals. Everything is 8ft-lbs well not everything but you know what I mean.
Old 05-21-2009, 11:03 PM
lt170chevelle's Avatar
yeah man they are not too bad.ive done a few 4l60e trannys now and is a great learning experience.One thing is dont cheap on the clutches and steels..and pay attention to the manual. I personally think its better to rebuild your own tranny and understand its workings that a way down the road if you start having issues you can usually have an idea of whgats going on.
Old 05-21-2009, 11:19 PM
artypyro's Avatar
the first one i put together i installed the forward sprag backwards. lol
id get a beast reaction shell also there like 50 bux
i took mine to a tranny shop and had them install the bushings and clean the case really good.
good luck
Old 05-22-2009, 08:47 AM
how much horsepower would this tranny be able to handle?
Old 05-22-2009, 02:18 PM
05gto60's Avatar
IF/WHEN something happens to mine, im gonna have to rebuild it myself. i dont want to but i can only get USPS over here, and i know they arent gonna send a transmission
Old 05-22-2009, 04:25 PM
goldmecham's Avatar
the hp it will handle depends on how well you build it. not just whats in a kit.
Old 05-22-2009, 05:00 PM
It'll handle anything you throw at it...until it gets bored and quits
Torque is really sneaky about searching high and low for that week link.
But seriously, unless you're making 500+ horsepower/torque, on slicks, and doing WOT dumps all the time, I wouldn't worry about it. Given that it's set up right with complimentary parts.
Old 05-22-2009, 06:22 PM
spaz1's Avatar
I did it but you need some special tools. It isn't very complicated.
Old 05-22-2009, 08:35 PM
could you please inform me of the tools ill be needing?
Old 05-22-2009, 08:47 PM
First and formost, snap ring pliars.
Spring compressors for the case and input shaft.
Sealing ring sizers for the input shaft and stator shaft.
Overrun and forward seal protectors
Bushing installers. Not the autozone kind. I got lucky on set of Ebay.
Slide hammer. Not necessary but makes life alittle easier.
Pump alignment band.
Alignment pins. I made some from old valve body bolts.
A shop press.
There are a bunch other special tools but if you're creative, you can do without them.
If you decide to do it yourself and get stuck on a certain part. I'll tell you what tricks I used.
Old 05-22-2009, 09:19 PM
spaz1's Avatar
^^ What he said and I also used a forward clutch spring compressor.
Old 05-22-2009, 09:23 PM
That's what I mean't when I said input shaft, but yeah that. Also forgot about the reverse drum springs. I've removed the input drum and reverse springs by hand. But you will not get them on by hand if you install the transgo springs.
Old 05-22-2009, 10:58 PM
ZMONSTER!'s Avatar
What are the manuals that yall used? Where did you get them? Ive got engine manuals but none for the tranny!
Old 05-23-2009, 12:23 AM
The factory service manual for your vehicle and/or ATSG manuals. Just search on Ebay for 4L60E. That would be the easiest.
Quick Reply: anyone rebuild a 4l60E themselves?
