##7 apply ring 3-4 clutch pack/installing z-pak
I am getting my parts together to build my 94 4l60e,I am wondering do I need the shorter #7 apply ring to install a z-pak?or does my tranny already have the #7 apply ring?
If it's out of a Z car it should have it. Especially if it has the "golden rooster".
It'll have a "7" on one of the legs where it meets the base.
stock is .075-.078 right?I read z pak comes with .062,maybye one or the other will get the clearence in range.
LS1Tech Sponsor
No but we do use either the TG stiffer springs or the factory square helper springs depending on the clutch set up to offset that issue. But as I said we have not really noted any issues with that. The few 3-4 clutch failures we have see were generally traced to some other underlying cause.
__________________
Your running that tight of clearance dry I take it? Just wondering since they recomend clearance set at .040-.050 I think. Do you run most of your clutch sets tight except for reverse? Thanks!
The first zpak I recieved had several retaining rings, the most recent one I recieved only had one and made it impossible to get the clearance I needed. All late model 60s come with the #7 apply ring.
I use the Red alto with kolene steels. The 9 friction set up. Clearance is recomended .020-.035 and no problems to date.
As far as 3-4 burnup, the HD2 kit comes with a few updates to fix it.
LS1Tech Sponsor
The 3-4 set is run with the tightest clearance in our unit and yes that it a dry setup on a build. After running on the dyno its actually opens up some. In fact simply applying it during the air check several times will generally open it up .05 or more . I have noted that .020 becomes .030 aprox after the dyno runs.
__________________
