where can i buy a reman trans pump for 98z28
Old 05-23-2009, 05:50 PM
im2fast4u98z28's Avatar
Default where can i buy a reman trans pump for 98z28
don't know much about them. i believe it's a 10 vane pump? some of the ones i've looked at say they fit 98&up but then i look at another and it says 99&up w/LS1? i assume they are all remanufactured in the same place so i'm looking for one cheap. please correct me if i'm wrong on anything.
Old 05-23-2009, 11:20 PM
FLT
FLT's Avatar
Make sure that you get one for a ls1. I have seen many guys get the wrong pump because of the change over in the transmission years. Basically the fbodies changed in 98. However some trucks with a v8 in the 99 model year could still use the earlier style depending on which motor was in the vehicle. The earlier pump uses a 298 millimeter stator. Make sure when you order a pump specify that you need a 13 vane pump with a 300 millimeter stator. Vince
Old 05-24-2009, 01:51 PM
driftpin's Avatar
I have used Transtar for all my tranny rebuld and hard parts. Great service and fast shipping. Very knowledgable staff too.
Old 05-24-2009, 02:30 PM
FLT
FLT's Avatar
PM returned. Good luck. Vince
Old 05-24-2009, 05:07 PM
i found a rebuild kit. is this everything i need? doesn't seem like enough parts?
here's the link : http://www.eatmyshifts.com/pl_4l60e.htm it's #5
Old 05-24-2009, 05:10 PM
or maybe this one?
http://cgi.ebay.com/ebaymotors/700R4...Q5fAccessories
Old 05-24-2009, 05:57 PM
driftpin's Avatar
Originally Posted by im2fast4u98z28
This one seems better then the first and if you want your pump gasket and O-ring, you can get them at Transtar item# (gasket) 74310A , (O-ring) 74311
You might want to throw a Shift kit in it while you have it out? I have the transgo. They make a good quality kit and the instructions are very well done. I wish the guy that did their instructions would do the one to set my clock on my DVD player, LOL
