Anyone else experience this? What could be causing it?
Not sure what's causing this...maybe someone else has experienced this and found the culprit? Basically, there is a studder in my trans (4L60E) during part throttle acceleration, in 2nd gear only... it happens between 2000-2500rpms every time. It studders only for a split second and then continues to shift later into 3rd, 4th as normal as I accelerate. I've pointed this out to my tuner but he never sees it on any of the data logs. Has anyone experienced this and what was the culprit in your trans?
Stroker2112
Stroker2112
