Trans Fluid ?
Trans Fluid ?
Quick one, I checked the fluids today and the fluid in my transmission its a stock 115k mile 98 T/A and is FN BROWN. It was good the last time I checked around 20k miles ago but I have since added a 224 cam and hade most of the bolt ons for the last 50k . I am running the stock stall as well, anyone have an approximate idea how long I have till it blows, fluid does not smell burnt it is just dirty. Car has been tuned and tq management was deleted ~45k ago.......Wife is gonna **** if it goes out, looking at trans company right now. Was supposed to have had a fluid change from previous owner and it looked nicce and clean and a little over filled when I bought it. Just wondering with the miles on it if it is gonna hold up, it my DD. Thanks!!!
Yea I was in the same boat as far as reading everything, truth is I installed the stealth II cam because of the lsa and being stock stall friendly but after acout 75 miles I pulled it out. Had a ton of valvetrain and I measured everthing so A friend had a crane 224/224-114 cam laying aroung that I threw in there, stressing about the stall the whole time. But yea I have to push a LITTLE harder on the brakes but from what I read I was going to have to two foot the pedal with everything I had to keep it from rolling! I do want a stall but with the age of the trans I really was worried, now I wonder how the cam will do if it was stalled. I have never been in a stalled auto so I am unsure how much a performance gain they make.........
I don't have an LS1 FSM handy but this is an excerpt from the Jeep Wrangler FSM I had on my flash drive:
I'm pretty sure that the Dextron fluid in our transmissions is the same way. If you don't know the last time it was changed I would change the fluid and filter. Don't go to places like jiffy lube as the flush process they use does not change the filter.
Mopar ATF +4, Automatic Transmission Fluid
when new is red in color. The ATF is dyed red so it
can be identified from other fluids used in the vehicle
such as engine oil or antifreeze. The red color is not
permanent and is not an indicator of fluid condition.
As the vehicle is driven, the ATF will begin to look
darker in color and may eventually become brown.
This is normal. ATF+4 also has a unique odor that
may change with age. Consequently, odor and color
cannot be used to indicate the fluid condition or the
need for a fluid change.
