Converter Diagnosis?
Is there anyway to tell if it is bad or not.
Here is whats going on...
Was having some problems with the trans overheating and fluid coming from the vent tube. So I drained the fluid and replaced the filter. I noticed a decent amount of metal dust in the pan, I just has my trans rebulit in August and rarely drive it, but just started having this problem last month. I did this and then I noticed trans fluid leaking from the front and looked up into the inspection cover and saw it leaking from the front seal. So I went and had the front seal replaced. Well, it did not work.. it is still leaking from the front seal. I dont mean a slow leak, I mean a decent size puddle in a matter of minutes.
I now have the trans off the car and am trying to figure out if I need to take it to a trans shop or just get a new converter. I would like to know what to tell the trans shop if I take it there besides its leaking???
Any Help..Thanks!
Any Help..Thanks!
