Transmission temp guage
I always just put my sender in the pressure port on the side of the trans, the port is already there and the sender that comes with the gauge fits right in with any adapters or anything, just thread it in and run your signal wire down to it. Its very simple. Just remember if you do this your temps on the gauge will read just a little higher than the actual fluid is, probably 15 degrees or so higher.
