Trans never starts off in 1st unless I manually start in 1
Old 06-14-2009, 08:29 PM
cpd004's Avatar
Default Trans never starts off in 1st unless I manually start in 1
Is this normal? I would think it should start in 1. The trans has been rebuilt and it has a shift kit. It's been so long since the car drove that I can't remember how it sed to be.
Old 06-14-2009, 09:23 PM
LS1Tech Sponsor
performabuilt's Avatar
Yes it should start in 1st. What shift kit do you have ? are you sure first is being commanded?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 06-14-2009, 09:25 PM
cpd004's Avatar
Trans Go. How do I know if it's being commanded? Is it through the PCM that it gets called for?
Old 06-15-2009, 12:19 AM
LS1Tech Sponsor
yes through the pcm you should be able to see it in na scanner
__________________
Call 888-744-6542
