I need convertor selection
I have a new car and combo. My original motor never got built(bad block).
I had my 8" fixed for it. It was supposed to be around 48-5000. I used it behind this combo. It is a turd up to about 330ft. then it goes ok.
95 camaro
3200# with driver.
355 sbc
11 to 1
edelbrock rpm heads
holley intake with 4150 throttle body
24# injectors
Cam
112 ls
Dur. .050 int. 230 exh. 238
lift .525 .525
TH-400
2.75 low gear set
28" tires
4.30 gears
First passes on the car tonight.
60ft 1.699
330ft 5.000
660ft 7.843
mph 86.54
I know its not right.
I shifted at 5000 because it just didn't feel like it was running.
help me please. What stall do I need?
95 camaro
3200# with driver.
355 sbc
11 to 1
edelbrock rpm heads
24# injectors
Cam
112 ls
lift .525 .525
TH-400
2.75 low gear set
28" tires
4.30 gears
60ft 1.699
330ft 5.000
660ft 7.843
mph 86.54
What are you stalling the car up to? Does it have a T Brake. Is this a NA stall or nitrous stall. You gears in your rear are to high dam. What size of tire are you running?
The car is a footbrake car. NA stall. I brought it up to 2400 and 2700. It wanted to push through the brakes after that.
tires are 28"
4.30 gears are to high????? need what numerically lower or higher?
tires are 28"
LS1Tech Sponsor
How much rpm do you turn. Have you checked your tune,fuel pressure etc,.If so you might need to losen it up a bit but with that gear and tire with a 275 low a 5000 should work pretty decent. If the sprague in the converter is not holding this could be your problem. You said you shifted it at 5000 then the converter should have never met complete coupling phase yet. I would go over the tune up before I condemed the converter.!!! my .02
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
I took it out today and pulled the trans apart also. Everything looks clean and great. I found a issue but I don't really know if this will cause it totally.
Forward clutch clearance was around .070
Direct clutch clearance was around .065
The car ran and pulled but if that is too loose which by tolerances it is would that cause the car to run but in a way slip the clutches.
They where not hot or burnt looking. They where clean and you can read all numbers and raybestos on the clutches.
