trans loses 3rd and o/d after 20 minutes of driving
Old 07-09-2009, 03:11 PM
DarkDemon's Avatar
Default trans loses 3rd and o/d after 20 minutes of driving
Works great then all of a sudden 3rd and o/d stop working. i park the car for an hour or so, and drive around and works fine.
Old 07-09-2009, 03:45 PM
01ssreda4's Avatar
is the trans low on fluid and/or overheating?
Old 07-09-2009, 04:30 PM
joecar's Avatar
What 01ssreda4 said... and also possibly a sticking valve.
Old 07-09-2009, 04:46 PM
DarkDemon's Avatar
trans level is good, has a cooler also. i swapped out the shift solenoids thinking it was that, but no luck.
Old 07-09-2009, 06:36 PM
BubaGumpShrimp's Avatar
did you just add a converter, if so you could be setting off limp mode.
Old 07-09-2009, 06:50 PM
built408's Avatar
does it still make the 1-2 shift when this happens?
Old 07-09-2009, 07:06 PM
My95Z's Avatar
Sounds like 3-4 clutch packs are letting go, when the fluid heats up it thins out and won't hold enough pressure.
Old 07-09-2009, 07:29 PM
DarkDemon's Avatar
i've had it for about a year
yes
damn that sucks but fawk it
Old 07-09-2009, 08:10 PM
2002CAMAROSSLS1T56's Avatar
Tune it for the converter even if it worked fine for a year. I've heard that a bunch of times that a converter swap ran fine on a stock tune then a long time after had issues typical of a non tuned high stall set up. And was cured by tuning only.
Old 07-09-2009, 10:57 PM
LS1Tech Sponsor
performabuilt's Avatar
I would definatley get it scanned before getting a trans I agree with what 2000 up there said have seen it many times
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 07-10-2009, 07:04 AM
what tuning did you have done if any and what is the stall speed of the converter
Old 07-10-2009, 07:31 AM
DarkDemon's Avatar
its got a speed density tune and a 3800 stall
Old 07-10-2009, 09:29 AM
misfire tables.
Old 07-10-2009, 10:08 AM
DarkDemon's Avatar
ran the codes and got p0103...could that be the problem i know its a maf code
Old 07-10-2009, 10:22 AM
Who did your tune?
Think, think real hard........maf code----speed density.
Did the infamous trans fryer do your tune? I'm curious to know.
Old 07-10-2009, 10:23 AM
DarkDemon's Avatar
lol local guy did it
Old 07-10-2009, 10:42 AM
Moderator
jimmyblue's Avatar
Is it a total fail, or just excess slippage (like maybe
the TCC refuses to lock, on an immature P1870
slip code that resets every key-on)? May need
to fix the TCC PWM settings to get "slip learning"
out of the picture and give it enough pressure to
work, or even bump base pressure (had to, on my
TCI 3000).
A bogus airflow goes to bogus trans delivered torque
goes to line pressure which could further aggravate
the situation.
Old 07-10-2009, 10:59 AM
Thats why if you run SD you tune for SD, and if you use a 3800 converter you tune for a 3800 converter.
Old 07-10-2009, 11:36 PM
conde'strans's Avatar
FAWK IT, just take off the converter and give it to me!
