TH350 pan gasket..
TH350 pan gasket..
What are you all using as far as tranny pan gaskets are concerned? I am using this very thin rubber crap that my local parts store had for like $5. They didn't have anything else. The reason I want to change it is because it is leaking lol Any ideas?
stamped pan or cast? i have used cork and fiber
if its a stamped steel pan, make sure it has not been over tightened, which actually lifts the pan away from the surface, makes it leak-ck around the bolt holes, knock them back flat, or level with the pan surface for best seal
