Shifter needs adjustment, but the other way
Old 07-13-2009, 07:52 PM
brianfromhawaii's Avatar
Default Shifter needs adjustment, but the other way
I put a new cable on my buddys auto camaro and when your in park its in park, but when you put it in drive its in neutral, 3rd is drive, first is second (i know because it commands second)
now i know you can adjust these.. if the cable gets stretched over time, but it seems like the cable needs to be stretched for it to even work!!! any ideas?
Old 07-13-2009, 11:13 PM
anyone?
Old 07-15-2009, 02:55 AM
cmon people.
Old 07-15-2009, 08:17 PM
Marc 85Z28's Avatar
The distance from reverse to park is much greater than between any other positions. It's probably not going all the way into park.
Have you at least even tried to adjust it?
Old 07-16-2009, 02:26 PM
i have, and it is going into park and then some.
Old 07-16-2009, 08:46 PM
FLT
FLT's Avatar
Try to set it in the neutral position and see how that works for you. I find that it is always best to have 2 people when doing this. This way you do not have to go back and forth while doing the adjustment. It's been a while since I have done this but I always find if you have someone keep the shifter in the car in neutral, while pushing it torwards reverse, this usually works. This way you just set the cable while it's attached and have person in the car check it. Hope this helps. Vince
Old 07-17-2009, 02:20 AM
thanks vince.
