B&M Pro Stick Intall, Do I need 2 cables?
1 Post
I bought a used pro stick out of who knows what car, but i coverted it to the 4 speed. Took the stock shifter out last night, as saw there were two cables going to the shifter. One has a hole off to the left about an inch away from the shifter and the main cable Im guessing goes all the way under the dash. My friend has the same shifter on his 70 Camaro and is only using one cable, so since I have two, which one do I use and whats the other one for?
1 Post
Ok, so ill just run the one cable, i have the 3 foot cable, that should be ok right? or do I need a longer one? I'll need to pick up a N safety switch or can I just make the factory one work somehow?
