not shifting
not shifting
I have a problem. My transmission has started to not want to shift when I floor it. My car is tuned, and the rev limiter is set to 300 RPMs higher thatn the shift point. It does fine for city driving. The guys who tunes my car changed my shift points and rev limiter a little higher to see if it did the samething and it did. No matter where my shift point is above 6,000 RPMs when I floor it, it just passes it and won't shift and start to bounce off the rev limiter. It won't shift till i let go of the gas. It does this on D and OD. It does this when i floor it no matter what speed I floor it from.
wellmy freind other than a tuning issue it sounds like its time to see the man if it wont shift at WOT ASIDE from a tuning issue sounds its done...what is the fluid condition and how many miles....give us a call and see whatwe can do
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
The oil is good. The only thing ever done to it is when I changed the trasmission oil, filter, rear main seal, and I had the shifter cable changed also, but that was done at 75,000 or 100,000 miles I'm not really sure. I have 148,500 miles on it right now. I did have the gasket on the pan changed about 5 months ago cuz it was leaking.
checked fluid level?
__________________
"All Motor 9 Second club member"
Have your tuner lower the WOT mph about 5-8 mph (upshift and downshifts). See if that helps. If there were no mods performed and it just started doing this all of a sudden, then chances are your tranny is going south. As mentioned above , make sure the fluid level is at the full mark at idle.
G/L
G/L
