Will the TH400 from a Supra fit on the LS1?
As the title says it all, I need to know whats the difference between the TH400 from a supra and the TH400 that has no overdrive... I mean, if I have a TH400 from a supra, will it work as a substitute for the 4l60e? what modifications are needed?
Thanks
Thanks
Will a BOP TH350 or a 200R4 bolt behind a 5.3 LS motor, reason I'm asking is I'm seriously considering about dropping a 5.3 LS truck motor into my 83 Regal Wagon where now a 3.8 resides, anyone have any info on this or have known someone that has done this to a G-body, looking for links and info on this,thanks.
Ron
Ron
Ron
Ron
So then any Chevy trans patern will bolt up, yes the 2004R is a dual mounting, BOP and Chevy, so the a 350 with the Chevy pattern and we are good to go correct?? thanks
Ron
Ron
Location: Your girl's back door giving her the long stroke while you're at work
I've got 5 in my TH350. The two on the left side above/below the dowel, two on the right side above/below the dowel, and the one at 11 o'clock(upper left side)
Thanks for the reply bro... but I might have difficulty doing so, because the transmissions usually in here come from broken cars outside of Lebanon which means they don't even know where the hell they came from! so I guess I should try checking something else, something maybe more evident in the transmission unit itself...
Anyone?
Anyone?
alright then thats the route Im taking, Im goin to try and install it stock, just to let the car move, no racing no nothing... just to take it and pass emissions and all so I can pay for some outstanding fees on it, then I will rebuild... so they are all the same in fitment and power?!
BOP means Buick, Oldsmobile, Pontiac. Those wont work on an LS1.
Can't be adapted either unless you cut the bellhousing off and use a readily available custom made bellhousing. Here in the US it's not worth it to adapt a th400 from bop to chevy.
A non sponsor makes them for Datsuns, fords, etc.
