trans pressure monitoring
not sure if i'm having issues with the trans or the parameters in the pcm. my problem is if a get hard on the gas or go wot, the car just revs like its in neutral. if i gently roll into it, i will spin the tires down the street. i talked to the guy that built the trans for me, said to look at the trans pressures, he's going to bring a guage over on monday to hook up to the port on the trans itself. wanted to know if there are any good pids to log to see what the pcm is seeing to compare the two?
or just ones to log in general to help in getting the issue sorted out.
i'm using efilive
i'm using efilive
