Help extermely hard shifts
Hey guys tranny has 40K on it and is not a daily driver more like weekend cruiser. Any way I turned the key and put the car in reverse and it slams hard into gear. Same with putting in drive.When driving it persists slamming into each gear. Parked the car came back a few days later and the same problem continued. Any idea what could be causing this? After doing a search it seems I have very high line pressure. Car was never tuned and is not setting off any codes.
Tranny gurus please give me some advice I want to install longtubes but will hold off until I can get this fixed. I hope its nothing blown inside the tranny.
Thanks in advance
Thanks in advance
[QUOTE=twitchtwice;12085604]may sound dumb but maybe check fluid levels
That was one of the first things I did tranny fluid right where it should be,
Thanks for all the responses. The winter project for me is going to be a built tranny with a stall so thank you for all the help I will definately be calling you (perfomabuilt) in a few months.
