th400 revs slow past 5500-6000
car is a SS 2002 camaro, th400 trans, moser rear. turbo setup making 800hp roughly. here is a log in a first gear take off. the car flashes and pulls but then has very little power above 5500. the injectors go flat also. here is the log
i also hit the trans brake and it will stall to 5k or higher if i like. it usually only went to 3k at best. does that mean the converters shot also?
jakeshoe-thank you for the info. have you seen this often?
I can't diagnose your car on the internet. You COULD have weak valve springs, tuning issues, fuel delivery problems, etc.
However I will say this,
if it only does it in 1st gear, it's not likely any of the above and is very likely the trans.
A fuel delivery problem will show up in 3rd gear not 1st, tuning issue would usually be across the gear ranges, as well a weak valve springs.
I build GM automatics exclusively for performance use. It sounds like an amateur built your TH400.
i dont think its tuning issues. i put my old tune back in and it still did it. the converter is getting sent off, so is the trans, at least ill be able to rule those out. i took a look at the valve springs and they looked normal. will the plugs show any signs of valve spring issues?
