Vigilante Stall Question
Looking at getting a 3200 Vigilante stall, and was wondering if I needed the single disk or the triple disk version, and what the difference is in the two?
Also looking for recommendations on where to buy from? Only sponsors that I found that carries them were speed inc and thunder racing.
single disc is a direct replacement from the factory unit basically with the same function. A triple disc can be "locked up" under WOT conditions which can be beneficial when racing. A single disc "should" only be locked up under part throttle conditions.
