700r4 swap
700r4 swap
i've read so many threads on the swap and i need to know what all i need the whole setup is coming out of a 97 camaro and is going in a 2002ss i have a ls1 flexplate the converter for the 700r4 out of the 97,cooler,trans mount and crossmember,shifter, i need to know what i need for as far as spacers or stuff like that to make everything line up with no issues
If it's coming out of a '97 and it was the stock transmission in that car then it isn't a 700R4, it's a 4L60E. And if it is a 4L60E it would be a lot easier to just get a 4L60E from a LS1 F-body (removable bell-housing) and then everything would just bolt up without all the headaches.
