TH400 tailshaft difference
Why is everyone worried about the tailshaft housing size... I mean I found alot of th400's here and I want to buy one, but the only one I found is the long tailshaft one...
I have a 240sx with an LS1, and I do all the custom work from the transmission mounts to the driveshaft, so should I care that the transmission is longer or shorter? power difference? anything at all that I should care about?!
I already have the LS1 + 4L60e on the car... bolted up, but the 4L60e gave up, so I'm going with a th400...
guys can you please check this torque converter, is it the one that should come with the th400, because I've seen others with different holes on them... so Im worried this could be the wrong torque converter or could be a different model one...
And why the hell does my tag say nothing like any other th400...?
the yellow tag on the side says:
N A
75 - NA 1184
what did this come from? and is it the proper TH400 I should be using on my
LS1
N A
75 - NA 1184
LS1
I replied in another thread you asked this question and figured I would post it here as well. BTW I think that trans came out of a 1975 vehicle.
The gm spacer would be the route I would take or get a custom stall converter with the correct pilot on it. To me it just makes sense.
The converter in the picture was what I would back in the day call a th350 converter. This was a very common style for th350 units in cars. However the 400 and the 350 converters are very much the same. Reason is because both units have the same spline counts for the stator, input shaft and the pump.
As for you question on will it bolt up to your flexplate. You will have to hold it up to what you plan on using to see if the bolt pattern for the converter pads is correct. Vince B
Thanks Vince, your so much Help bro... I think I'd go with this Torque converter and not the th400 one because it looks lighter than the th400's torque... is that true by any means..?
The kit Im getting which would help me get this tranny behind my LS1 is the kit from Advanceadapters.com it includes a flexplate and a spacer... to make it work...
Thanks
Thanks
Thanks
Thanks
I can understand the flex plate and the spacer from them if your oem flexplate does not work. However when you mention advanced adapters I'm thinking they are trying to sell you something that goes between the engine and trans. I do not think that is needed. Vince B
The original poster in this thread does not have a fbody so in his case he needs one regardless. That is a good question in your case. I'm pretty sure the th400 is shorter with the short tail than the 4l60e. So you might have an issue with this. I would need to make some measurements of units I have at the shop to confirm this. Maybe someone that has done this will post up or you can always check the stickies at the top of the page. Vince B
