Lt1 retune after stall ?
Old 09-05-2009, 11:33 PM
94LTZ's Avatar
Default Lt1 retune after stall ?
I've been looking into converters for my current set up and i've been told that if i go over 3000 rpm stall that i have to have my car tuned or else it wont shift into 2nd at WOT?? Any one have an input on this? Thanks
Old 09-06-2009, 12:24 AM
PedaltoMetal's Avatar
I have a 3000 stall no tune and it shifts fine at WOT. I need to have it tuned I just keep putting it off. Only drive the car once a week or so. I think when dealing with higher stalls, the PCM thinks it's slipping and the active/adaptive learning tries to adjust the shift timing to compensate for the "wear" it thinks it's seeing when looking at RPM vs VSS. Make sense?
Old 09-06-2009, 12:28 AM
94LTZ's Avatar
Yeah it does, i'm going to a 3400 stall and the car is only a weekend car and i just don't want to run into the problem of it not shifting and especially on the bottle in first and hitting the limiter would do some damage..
Old 09-06-2009, 12:31 AM
That's why you use a window switch, but yeah I hear ya. A certain tuner quoted me 75 to adjust for stall. Don't know if they're a sponsor on here or not.
Old 09-06-2009, 12:34 AM
94LTZ's Avatar
I have a local tuner told me he would do it for 50 and yes a window switch would be nice but money is tight and it would be cheaper to get the tune.. Thanks
Old 09-06-2009, 12:36 AM
Wow 50? I thought 75 was a good deal. Good luck.
Old 09-06-2009, 12:41 AM
94LTZ's Avatar
Yeah the guy is cutting me a deal which is nice right now lol.. I'm just not sure if i really need it, i've only heard of one person needing it and they run a 3600.. The one i will be running is a 3400.. Thanks
Old 09-06-2009, 11:14 PM
nnag's Avatar
94LTZ, the 3500 you installed for me earlier this year shifted fine with no tuning. Not an LT1, but whatever.. Think you would be fine.
