New Pro Yank 3600 and FLT-VII go 152.64Mph
Old 09-08-2009, 09:25 AM
Black X's Avatar
Default New Pro Yank 3600 and FLT-VII go 152.64Mph
I recently installed a New Pro Yank 3600 looking for a little more efficiancy in the big end.
Combo is a single PT88 on a 370 Iron block.
Got to the track friday to test it out.
Here is the video
http://www.youtube.com/watch?v=ffMhSDTuEuM
First pass was at 10psi. Just feeling things out.
Second pass was 16psi + 100 Nitrous the whole way.
Sixty was a little soft, and I got the limiter on the 1-2shift.
This is 6mph faster then my old converter on the same tuneup. Truck weight is 4050Lbs with me in it.
Big thanks to Dave at YANK for the new converter. All I can say is wow, once I clicked third gear it felt like the truck was on a mission.
Thanks as always to Chuck and the guys at FLT for a solid trans!
Old 09-08-2009, 04:06 PM
obZidian's Avatar
Interesting as this is the same verter I have in my camaro project... but on a 3200.
Old 09-08-2009, 06:28 PM
Andy @ FLT's Avatar
Congrats James!!!!
I knew you would get there, what should we expect next????
Old 09-08-2009, 06:34 PM
01ssreda4's Avatar
wow, nice times
Old 09-09-2009, 12:02 AM
Black X's Avatar
Originally Posted by Andy @ FLT
Congrats James!!!!
Thanks for your support Andy, only about 1 month of racing left here. I hope to get a clean pass with a good sixty foot and not get the limiter on the 1-2 shift.
Considering a diet for the truck over the winter. Other then that continue beating this trans like it owes me rent
Old 09-09-2009, 03:42 AM
ramairws6's Avatar
Awesome run! What vertor were you running before this? I'm thinking about changing from my PY3400 to the PY3600 over the winter...........
Old 09-09-2009, 08:42 AM
FLT
FLT's Avatar
Looks like you need to update your MPH sig Congrats once again James!
Chuck
Old 10-12-2009, 01:59 AM
ramairws6's Avatar
What's this truck weigh?! Do you run a vacuumn modulator??All I can say is "WOW"!!
Old 10-12-2009, 02:22 AM
ramairws6's Avatar
Ooops, I see the weight now.....................
Old 10-16-2009, 10:38 AM
LSevil1's Avatar
That S10 is bad ***! Looks like 8's for you next year. I am looking at this trans for next year but what rear gear are you running?
Tim
Old 10-17-2009, 11:46 AM
Black X's Avatar
Tim
I run a 3.55 gear and a 30" tall tire. Thanks for the kind words about the truck.
Old 10-20-2009, 09:10 AM
MY99TAWS6's Avatar
So this is trans brake and 4l80?
So what power do you think you are at to get that mph?
Old 10-20-2009, 11:19 AM
Black X's Avatar
Line Pressure is still computer controlled with some tweaks in the tune.
This is the new Finishline Maximum performance 4L65E foot braked. It has not been on the dyno this year but its 10MPH faster then it was at 700RWHP so I estimate somwhere around 900-950RWHP range.
Quick Reply: New Pro Yank 3600 and FLT-VII go 152.64Mph
