4l60e LEAKING
4l60e LEAKING
I have a leak coming from my 4l60e trans. The trans has about 500 miles on the performance build done to it. I just had a ls6 engine installed sence then and a 2800 yank stall. sence I got it back there is tranny fluid leaking out from somewhere. It was covered with fluid so its hard to tell where it was coming from.
I jacked it up and cleaned it all off tightened the pan bolts then took it for a ride. I went about 12 miles and no leak.
The wife and I went for a 40 mile stop and go ride 2 days later and it was leaking again. I parked it in a oil free spot on driveway and it was coming out pretty good looked like front of trans I thought input seal.
I jacked the car up and cleaned it all off again and had the car running for about 45 min to see if i could find the leak for sure but again not a drop. I ran it threw all the gears and checked the fluid level and topped it off and nothing.
The shop I had install the motor is giving me the run around about it not being there fault and I cant afford there labor cost when they are already saying they didnt make a mistake.
Id be very greatful for any help. THANX.
