Stall and cam dilemma
Hello! My name is Kalee and I recently bought my 2nd WS6. It is an automatic 2002 Trans Am WS6. It is stock and I plan on putting long tube headers, y pipe and cam on it. I wanted to get a cam without a stall right now but everyone has been telling me that I might as well get both since I want a cam with a semi-rough idle, LOUD sound and awesome performance, nothing wimpy. I am not at all familiar with what size cam or stall I need and although I know its going to cost some money for all this I dont want to spend tons. Any suggestions on stall and cam??
"All Motor 9 Second club member"
You really should do the stall first. If you go with a semi radical cam with the stock converter you will have issues as the cam will usually require a higher idle rpm as well as some other tuning to get the car running nice. It will be an absolute turd without a stall unless you are moving pretty good with the rpms up in the powerband. (No fun at all)
It really depends on your goals, but if you just want just a choppy idle and don't care about a big dyno number, I'd stick with a valvetrain friendly cam that has a low ICL.
Contact Patrick G. He's fairly close to you and can spec out the perfect cam for what an off the shelf cam would cost and can tune it to idle smooth as stock and still give ya the rumpity rump you are looking for.
I would contact Circle D In Houston for your converter choice once you decide on a cam. The 4C is a fun TC and will work well with a decent sized cam.
G/L
G/L
G/L
G/L
OP, is this a DD or a weekend warrior, track car.... ? more info= better reccomendations.
