Ratchet shifter?????
Old 09-10-2009, 06:47 AM
96formulabird's Avatar
Default Ratchet shifter?????
ok guys in my 96 formula i have been throwing this idea around. i would like to put some type of ratchet shifter in, but i want it in the stock center console. so you cant see the base of it, just the acctual handle and all. can this be done fairly easy and i also need the brand and all that of a good ratchet shifter. any help would be greatly appreciated... thanks
Old 09-10-2009, 09:15 AM
Randy WS6's Avatar
Allot of guys are using the B&M Quick Silver ratchet shift.
Old 09-10-2009, 09:33 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I've got a B&M Pro Ratchet in my CETA
Attached Thumbnails Ratchet shifter?????-l_ef7962964bf846a583318c6905d69daf.jpg
Old 09-10-2009, 10:26 AM
MurphyTex's Avatar
Z28/2002:
That set up looks pretty slick. Was it fairly easy to do?
Anyone else with any more pics of their set ups?
Old 09-10-2009, 12:53 PM
Shoulder Shaker's Avatar
I have the B&M ripper shifter in mine. I will try to get some pics for you. It wasn't hard at all and I think it still retains the factory look.
Old 09-10-2009, 01:00 PM
Z28/2002's Avatar
Originally Posted by MurphyTex
Z28/2002:
The only PITA was making the hole for the cable to go through. It was a 6 spd car and I had to make a cover for the tunnel and just bolted the shifter to it. Didn't use any spacers or anything but had to trim a little on the console by the cig lighter but you don't see it with the shifter boot on it.
Old 09-10-2009, 07:57 PM
yes if you could get a few pics... i would like to tackle this somewhat soon. the main reason is cause i want something different and i would like it to still look stock with the center console kinda. lol thanks for all the help guys.
Z28/2002 i was going to say with your shift boot on it still looks like a 6-speed car lol. but looks good. hope when i figure everything out it turns out like that.
Old 09-10-2009, 11:22 PM
Z28/2002's Avatar
yeah that was the idea, but it's a TH350
Old 09-10-2009, 11:47 PM
demonpixel's Avatar
Mine's a 93 Camaro, automatic, B&M Hammer. Here's how it turned out with the stock center console before I put the boot on it:
Hope that helps.
Old 09-11-2009, 06:41 AM
Hope that helps.
yes that helps out alot... thanks thats what i hope mine ends up looking like.
Old 09-11-2009, 08:20 AM
demonpixel's Avatar
cool man, just hit me up if you need any help
Old 09-11-2009, 08:59 AM
MurphyTex's Avatar
demonpixel...that looks nice. I like your set up, looks like a stock install but with a performance part. Just what I want to do.
But does anyone have a pic of their set up in an LS1 car? A 2001 vert to be specific.
Old 09-15-2009, 08:21 PM
myltwon's Avatar
I have a B&M quicksilver for sale for cheap if you're interested.
pm me
Old 09-16-2009, 05:46 AM
Z28/2002's Avatar
Pic in post #3 is an LS1 car
Old 10-18-2009, 10:21 AM
TJ
TJ's Avatar
did you omit the lever for reverse, or is it hidden under the boot?
Old 10-19-2009, 02:59 PM
Z28/2002's Avatar
It's under the boot
Old 10-19-2009, 05:39 PM
TJ
TJ's Avatar
It's under the boot
easy access, or hunt and fish?
Old 10-20-2009, 06:26 AM
Z28/2002's Avatar
Once you drive it a couple times, you get used to where it's at
Quick Reply: Ratchet shifter?????
