4l80e Crank Spacer
Old 09-22-2009, 10:17 AM
Bucktooth's Avatar
Default 4l80e Crank Spacer
I have a 4l80e in my fbody. The bottom picture is my ls1, i attached the 4l80e to it without the spacer and it worked fine. I have heard people say you need it, the top picture has it. Would you remove the crank spacer? Any thoughts? Maybe this is just for trucks....
Old 09-22-2009, 12:50 PM
Gingervitis Addict
slow67's Avatar
If you use a truck converter leave it. If you have a custom built converter for the LS1 flexplate (spacerless) take it off.
Old 09-23-2009, 12:37 AM
MY99TAWS6's Avatar
Ok so I have a py 3400 e going in with speed inc flexplate not tci flexplate and callies crank in my 408. Do I need this spacer thing??
Old 09-30-2009, 10:11 PM
Bucktooth's Avatar
Sounds like only if you buy a truck converter you would need it. I would say no.
