M6 - a4 - th400 ??
Old 10-02-2009, 12:36 AM
209ryder's Avatar
Default M6 - a4 - th400 ??
So are the trq arm mounts from a auto to a manual the same on a Trans am 98 -02??? Im selling my 6spd and going to a th400 and the guy thats buying mine want my bellhousing bolts and trq arm mounts ??? Im obviously gonna need the mstill so i was wondering why he would ask for those ??? They are the same right ??? This is what he said he needed ??? Just curious cause i dont want to sell **** that i will need and he dont ??? Need some help cause im getting a complete th400 swap just need a flexplate ?? what is a good one to buy ??? and where
6-speed tranny
Shifter with ****
Lower shifter boot
Bellhousing with bolts
Master cylinder with bolts washers nuts (2)
T56 crossmember
6-speed console top
Clutch pedal
Clutch pedal retaining clip
Clutch pedal return spring
Clutch pedal pivot bushing (2)
Neutral safety switch
Torque arm mount and bracket inner
Torque arm mount and bracket outer
Slave cylinder bolts (2)
Old 10-02-2009, 01:28 AM
209ryder's Avatar
need some help guys
