Hot
Old 10-08-2009, 11:19 PM
mikemunoz's Avatar
Default Hot
I have a yank ss4000 stall and performance built tranny with dual tranny coolers. My question is why does it get really hot next to the gas petal when im driving is that normal? Any info will help out
Old 10-09-2009, 08:17 AM
FLT
FLT's Avatar
Being that the exhaust and trans are right there I would say it's normal. You could always try to wrap the exhaust and install a heat shield on the floor to help correct this. Vince Bielanski
Old 10-09-2009, 09:44 AM
mikemunoz's Avatar
where can i get a heat shield from
Old 10-09-2009, 11:02 AM
01ssreda4's Avatar
Your car should have come with one stock.
Old 10-10-2009, 07:02 AM
FLT
FLT's Avatar
Not sure if they all have them but it would be something that you would have to fabricate if you do not have one. This would be something that you would have to construct out of thin piece of tin or aluminum. Then space it off the floor boards a bit so air can be allowed to flow above and below it. You will definitely be fabricating this if you so choose to try to do it. Vince Bielanski
