Performabuilt lvl2 Yank4000ss Overheating?
Old 11-01-2009, 11:54 AM
BennyB's Avatar
Default Performabuilt lvl2 Yank4000ss Overheating?
Like stated in the title i just installed a Performabuilt lvl2 trans after my stocker went. The car runs fine for a while, but after an hour or so of driving the car doesnt want to lock up and it seems like the trans slips real bad. I then have to turn the car off and back on again for it to run normal. It did the same thing with the stock trans after I installed my Yank SS4000. Should i run 2 coolers? or maybe a cooler with a fan? Is heat whats causing this? Any suggustions or help is greatly appreciated here. Thanks.
Old 11-01-2009, 11:56 AM
BennyB's Avatar
I knew I should have installed a trans temp guage when i installed this trans.
Old 11-01-2009, 12:00 PM
JeaneZ28's Avatar
Do you have an ideal what the temp is? Did you get the car tuned after the stall?
Old 11-01-2009, 12:05 PM
BennyB's Avatar
The car was tuned after the stall and I dont have a clue what temp the trans is at all i know is after a while of running the car the cooler seems hot as hell.
Old 11-01-2009, 12:14 PM
JeaneZ28's Avatar
You could buy a laser temp gun to make sure its actually overheating.
Old 11-01-2009, 12:19 PM
BennyB's Avatar
I just dont see whatelse it could be. Its very frustrating though. I suppose this would be a lot easier if I knew what temp the trans was running at.
Old 11-01-2009, 12:25 PM
themack56's Avatar
can you get pics of the tranny cooler lines routing?
Old 11-01-2009, 12:27 PM
BennyB's Avatar
ya i can try and get some today.
Old 11-01-2009, 12:29 PM
JeaneZ28's Avatar
I know what you mean I'm having trouble with mine right now. I cant tell if its the trans or something else. No one can figure out what it is and I'm real frustrated.
Old 11-01-2009, 12:54 PM
BennyB's Avatar
Here are some pics... not very good i know[IMG][/IMG]
Old 11-01-2009, 12:55 PM
themack56's Avatar
cant see it!!!
BennyB's Avatar
Old 11-01-2009, 12:57 PM
BennyB's Avatar
Old 11-01-2009, 12:58 PM
BennyB's Avatar
Old 11-01-2009, 12:59 PM
BennyB's Avatar
Old 11-01-2009, 01:00 PM
FLT
FLT's Avatar
I think you might have a code issue that is keeping the lockup form not working. Have you tried to scan your vehicle for codes? Vince
Old 11-01-2009, 01:03 PM
BennyB's Avatar
The thing is is the day i got everything done i had it out and put over 100 miles on it that night with no issues. Today i take it out i have an issue within the first 30 mins. The only difference between today and yesterday is that its a bit hotter today... 15-20 degrees hotter... I will get a scan tool and scan it tonight.
Old 11-01-2009, 01:20 PM
BennyB's Avatar
Im going to get it scanned now Ill let you know the results.
Old 11-01-2009, 01:58 PM
LS1Tech Sponsor
performabuilt's Avatar
Yes sounds like you are setting codes possibly a po757 i would guess. or with no lockup possibily being disabled by engine missfire detection.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-01-2009, 05:47 PM
02 BLK WS6's Avatar
You need a tune for the higher stall converter....
