transmission making sqeaking noise...????
I've recently noticed a small squealing / sqeeking noise that seems to be coming from the internal transmission. I didn't think it was the tranny at first, but I noticed that when I put it in gear the sound goes away. It only makes the noise when in Park or Neutral.
It's a very small noise, and it doesn't always do it.....the transmission is full and clean and shifts awesome!!! Car only has 58K on it, and the trans has always been serviced around every 20-30k.
stock tranny and stock converter
Any suggestions????
Any suggestions????
Click the user profile and check the last visit, he hasn't logged on since 2/26/2010 so you probably won't get an answer.
A noise problem like this is probably something other than the transmission.
It could be loose flexplate, or converter bolts, or a cracked flexplate. But it's probably not transmission related.
Usually to isolate this problem I'd run the car, get under it and move stuff around like the exhaust, engine and trans mounts, etc. Heat shields.
Any suggestions????
Any suggestions????
also this is a 5.3 swap into an 89 blazer, trans is a 700r4 with tci reverse manual valve body
Might be the pressure regulator buzzing.
You could let it buzz, then remove the tv cable and pull it, see if the noise changes.
It might need a land removed from the pressure regulator valve in the pump. This was a standard modification from a long time ago, seems like it should be done already.
It's really hard to say what it is without being there.
