4l60e limp mode fix??
Old 11-17-2009, 08:10 AM
velox65's Avatar
Default 4l60e limp mode fix??
Ok well after struggling with my swap its done,but my tranny is in limp mode, all the fuses appear good, what steps do I need to take to fix this?
Old 11-17-2009, 09:43 AM
LS1Tech Sponsor
performabuilt's Avatar
First thing is hook a scanner up and see what codes are present.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-17-2009, 10:53 AM
velox65's Avatar
Ok here's the codes, I know I have bad o2s
po134-
po154-
po713-
po740-
po753-
po758-
po785
and p1860.
Old 11-17-2009, 11:42 AM
LS1Tech Sponsor
looks to be a wiring or no power issue, Check that you have 12v on pin e in the connector to the trans
__________________
Call 888-744-6542
Old 11-17-2009, 01:43 PM
Gingervitis Addict
slow67's Avatar
X2...sounds like no power....
Old 11-17-2009, 07:56 PM
velox65's Avatar
ok I'll check that tomorrow evening, which pin is E?
Old 11-17-2009, 08:24 PM
Gingervitis Addict
slow67's Avatar
Should be the red wire. Look at the connector when you unplug it, it labels the pins.
Old 11-18-2009, 12:43 PM
velox65's Avatar
assuming this is the problem can I just hook the wire up to a keyed hot wire?
Old 11-18-2009, 12:55 PM
Gingervitis Addict
slow67's Avatar
As long as the circuit is capable of 10 additional amps and is fused (7.5 or 10A for the tranny).
Old 11-18-2009, 07:05 PM
velox65's Avatar
Ok well it had power at the wire by the PCM to the connector but I didn't get to check the actual connector. Next step?
Old 11-18-2009, 11:16 PM
LS1Tech Sponsor
Check the terninal at the connector. the start checking chasis grounds and pcm ground wires
__________________
Call 888-744-6542
Old 11-22-2009, 04:36 PM
velox65's Avatar
any wat to just bypass that crap all together? eliminate to limp mode that is?
Quick Reply: 4l60e limp mode fix??
