4l60e wont shift past 2nd on startup
Old 11-17-2009, 04:34 PM
deepstage69's Avatar
Default 4l60e wont shift past 2nd on startup
Its a 95 model, wont shift past second when first started up, once in second its stays there. here the thing if you go down the street and park and cut the vehicle off for a couple mins, its shifts fine. Now i did do a trangso hd shift kit and new filter, but it was doing this before i did those.
When it is stuck in 2nd i can manually shift into first and have reverse as well.
Why would it do this on startup
