th350 swap questions
so i am getting a redneck th350 with convertor that has the longer snout for the ls1. I am also getting it with the 9" tailshaft to use my stock DS. For the th350 do you need to modify the trans crossmember like the th400? Also does the torque arm mount in the stock location? just trying to make sure i have everything before i start the swap. I will also be getting a ratchet shifter.
