Tranny shifting pre-maturely
Old 12-03-2009, 08:42 PM
pillarpod's Avatar
Default Tranny shifting pre-maturely
Tranny was built less then 4k ago. at WOT my tranny shifts pre-maturely...At WOT the car oways shifted at 124mph to go into over drive now it shift into over drive around 94mph 1-2 it shifting at 3000rpms....any ideas on how to fix it?
Old 12-03-2009, 11:06 PM
LS1Tech Sponsor
performabuilt's Avatar
If its a 4l60e trans shift points are completely pcm controlled so something going on with tuning/programing or a sensor unless you have changed te rear end or something or put in a higher stall etc
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-04-2009, 10:06 AM
pillarpod's Avatar
i had a 2300 stall put in and rear in is stock. Does the Trans Go shift kits require an extra quart of tranny fluid?
Old 12-04-2009, 10:37 AM
Moderator
jimmyblue's Avatar
On LS1s a TPS overvoltage at WOT will cause this kind
of behavior. I don't know about LT1s. Put the meter to
it and check your shop manual for what the fault voltage
max might be.
Old 12-04-2009, 11:07 AM
pillarpod's Avatar
if it did that, wouldn't kick on my service light or no?
Old 12-04-2009, 11:46 AM
LS1Tech Sponsor
Actually no thats a comon misconception codes are not always set when sensors are wrong. The PCM only knows a ceratin range it should be in and if its not then you will get a code but if its reading within that range but not right for conditions a code may not be set .
__________________
Call 888-744-6542
Old 12-04-2009, 12:47 PM
pillarpod's Avatar
how do i check the TPS? (also what does TPS stand for?)
Old 12-04-2009, 02:45 PM
Moderator
jimmyblue's Avatar
TPS=throttle position sensor. Easiest way to mess up
is over-aggressive bump-stop grinding, but bad ground
can also skew it.
On LS1s the TPS will set a code if it's over 4.75V for
more than 10 seconds (something like that). You may
not have that kind of time-over-target in street driving.
But any time it's over 4.75V it will immediately fall into
some self-protection modes like short shifting the trans,
code or not.
Old 12-05-2009, 08:22 PM
pillarpod's Avatar
my second question is the TransGo shift kit Stage 2 take an extra quart of tranny fluid? The only reason why i ask is after i go my car back i drove it around for about 2 weeks and i decided to check my tranny fluid. Well they over filled it by 1 quart, so i drained a quart out and drove it around. It drives fine but again at WOT it bangs goin 1-2 and 2-3. The sound is like some one is taking a hammer and taking one big hit when it shifts.
Old 12-05-2009, 09:57 PM
southpaw0314's Avatar
could be trans mount from firmer shifts
Old 12-06-2009, 07:46 AM
FLT
FLT's Avatar
With a 2300 stall the shifts will be more noticeable. As far as the 1-2 shift the amount of washers used in the 1-2 accumulator housing could be an issue. Also if the installer flipped the 1-2 acc valve and sleeve in the valve body or if you have a sticky 1-2 acc valve this can be an issue as well. I have seen many times when the installer is not familiar with this type of work. The last thing to look at is how large the 1-2 feed hole is in the separator plate. With a lower stall I would have probably went with a smaller hole providing that the other things I have mentioned are correct. Vince
