A4 transmission noise
Old 12-08-2009, 03:07 PM
jblack245's Avatar
Default A4 transmission noise
after a drive when i put my car in park or neutral i hear a whine noise almost like the sound from rear end whine. it only does it in park or neutral. other than that no other probs with it. shifts fine, fluid level ok. any ideas?
Old 12-08-2009, 04:14 PM
382ssz28's Avatar
Is it coming from the bellhousing area?
Old 12-09-2009, 06:54 PM
jblack245's Avatar
i dont know where its coming from. somewhere in transmission or near
Old 12-09-2009, 07:15 PM
silverz28camaro's Avatar
I believe when the tranny is in park or nuetral the input shaft/drum spins, when its in gear it will engage the forward clutches and stop spinning until the car moves, so maybe somthing to do with that part of the tranny would be my guess as long as your sure its coming from the tranny.
maybe the front planetary is having issues? I think that will spin in P and N. I wouldn't think it would be the pump because it should spin in gear also.
If you rev it in P or N will the noise go with rpm? or is the noise a steady noise?
Old 12-09-2009, 08:22 PM
jblack245's Avatar
When I rev in P or N I don't hear the sound any more. Don't know if exhaust cover the sound but even at low rpm around 1500 I don't hear it. Exhaust not that loud tho but I don't hear the noise when I rev low
Old 12-09-2009, 08:39 PM
This will be hard to guess over the internet..LOL. If there is a local tranny shop, maybe swing by and see if someone has the time to look or hear it. If you do that I would usually through the mechanic a few bucks, kinda like a tip, even only $10 will be appriciated, keep in mind that their time spent not rebuilding tranny's is lost time and money out of their pocket.
Old 12-10-2009, 09:24 PM
joecar's Avatar
It could possibly be the pressure regulator buzzing... it can do this when there is no load... when you increase the load it goes away.
Old 12-10-2009, 11:19 PM
jblack245's Avatar
if it is that, is that bad or normal?
Old 12-10-2009, 11:32 PM
jblack245's Avatar
When I came home from school today I put it in P no noise. Put in N no noise. Then I put it back in P and rev to about 3000rpm and when it went back to idle the noise came back. When I put it in D then R and back to N and P it goes away
Old 12-11-2009, 03:14 AM
joecar's Avatar
The pressure regulator valve can sometimes oscillate rapidly, causing that a buzz or whine sound...
It may be due to various things:
- excessive clearance of the valve in the bore,
- presence of air,
- it might just do it anyway,
- other...
Did it just start happening, or was it always there...?
I don't know, if it's not overly loud it's probably ok.
Old 12-11-2009, 08:30 AM
jblack245's Avatar
It just started about 2 weeks ago. I also have a dyno tune I got like 2yrs ago but don't remember if he did any tuning to the transmission
Old 12-21-2009, 02:58 PM
jblack245's Avatar
now when i go from park or neutral to drive or reverse it jerks hard like it want to pull while i am on the foot break
Old 12-26-2009, 02:05 PM
jblack245's Avatar
bump...
Old 07-21-2010, 07:59 PM
lrazer's Avatar
did u figure it out?
