Where to get bolts?
Where to get bolts?
Im rebuilding a 4l60 and the internal bell housing bolt's heads stripped out. Apparently GM used a special size torqs(sp?) bit for those. I would up having to grind off some of the head and weld another bolt to it and back it out with the help of a torch.
The dealer wants $8 a bolt and I need 8 of them. Just wondering if I had any other options?
It is doubtful that the big box hardware stores are going to have that big of a selection of metric bolts. I would pull out the phone book and look for a local bolt and screw place or a Fastenal store. I have mine out right now as well and I will probably replace them with some regular hex head bolts as well.
Josh
Josh
It's a torx T-50 plus (note the plus). It's not the tamper resistant torx, that's different and has the little stud in the center of the fastener. Its a torx with rounded sides to have a more positive engagement.
If you're asking about different bolts that are the same size but different head than i'm sorry, i can't help.
