4l60E wont shift at WOT!!
Old 12-20-2009, 12:17 PM
1bad02's Avatar
Question 4l60E wont shift at WOT!!
I have seen a couple threads about the same thing, The tranny shifts perfect at regular speeds and 1/2 throttle but when i go at WOT it wont shift at all. I took it to a local tuner already & its still doing the same. My question is that when he was messing around with the tune he was able to make it shift with his laptop, he told me that he had to "FORCE THE SHIFT" & it worked good. Is it the tranny for sure?
Old 12-20-2009, 12:51 PM
Camaro-BMF's Avatar
Dude, I just got my tranny back friday ran fine for about 4 hours, and is doing the same exact thing yours is ...what is it with these stupid trannys...im very Curious to know what is it..... Hope someone jumps in quick
97/Z28 Automatic
Old 12-20-2009, 03:41 PM
1bad02's Avatar
Yeah Hopefully
Old 12-20-2009, 04:00 PM
baalic's Avatar
in wot it wont shift into 4th if your in 3rd ....or do you mean it wont down shift? need more info...3rd gear is the fastest gear 4th gear is the highwaygear
Old 12-20-2009, 04:15 PM
1bad02's Avatar
No matter what gear im in when i go WOT it doesnt up shift. It downshifts fine.
Old 12-20-2009, 05:41 PM
LS1Tech Sponsor
performabuilt's Avatar
If he was able to force the shift with his tuner then the issue is not with the trans but rather the car, I have seen this a few times its particularly common with the 98 model year in particular. I do not know the solution some have found the issue with the tps was a problem something to look into
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-20-2009, 06:02 PM
1bad02's Avatar
Thanks for you help, Ill look into it.
Old 12-20-2009, 06:39 PM
LS1Tech Sponsor
Slowhawk's Avatar
Setting the WOT shift can be touchy.Expecially if it has a converter and deeper rear gears.
Old 12-20-2009, 07:29 PM
FLT
FLT's Avatar
^^^^I recomend a good tuner.^^^^Then again starting with a good trans helps!
Old 12-20-2009, 09:45 PM
1bad02's Avatar
I was also thinking it can be the tune. I had the pcm scanned & it picked up a bad TPS & got that changed with a new one. It doesnt read anymore sensors so I was thinking it was the Tune.. What do you guy think?
Old 12-20-2009, 10:32 PM
slo_lt1's Avatar
my last z was doing this it ended up being the converter ...and it took the trans with it
Old 12-23-2009, 07:38 PM
1qwkz's Avatar
ive had the same problem except with an older car :/
Old 12-24-2009, 08:37 AM
2001slppewterss's Avatar
try adjusting your throttle cable and checking your TPS voltage.
Old 12-24-2009, 08:54 AM
omcar's Avatar
after installing my shift kit / converter, mine did the same thing until I had the torque mgt feature deleted..now it's all good.
Quick Reply: 4l60E wont shift at WOT!!
