transbrake clutch question
Old 12-22-2009, 01:17 PM
rocketman442's Avatar
Default transbrake clutch question
What clutches is everyone using with a transbraked th350 that sees street use?
Old 12-22-2009, 04:52 PM
yfz450's Avatar
we install the Borg warner Hi Energy clutches
Old 12-22-2009, 07:20 PM
WE TODD DID's Avatar
The clutch plates aren't particularly important with the transbrake. It's setting the transmission up for the brake is where attention to detail comes to play.
Old 12-23-2009, 11:44 AM
I'm sure stock replacement clutches wouldnt like the abuse dealt out from a brake. Of couse attention to detail would be required as with any high performance part.
Old 12-23-2009, 07:52 PM
If you're sure, then don't use them. There are plenty of other parts in that transmission that I would address when using a transbrake, other than the clutches.
Old 12-23-2009, 10:59 PM
I have all the upgraded hard parts, just asking about clutches.
Old 12-24-2009, 10:12 PM
Stay away from raybestos. Use borg warner waffle or grooved frictions. Machine the direct drum piston and put 6 frictions in the direct.
Old 12-24-2009, 10:50 PM
Cool, anything specal for the low/reverse? Those are the two that engage when the brake is engaged correct?
