4L70E Leak if Overfilled?
Hey like the title states... could a silverados 4L70E tranny leak if it was overfilled? It is registering on the stick about a half to a quart over filled... thats a guess. Its about a 1/4-1/3 of an inch higher than it should be on the stick. So could it leak if I overfilled it? I did a converter change and its leaking now a little bit so i assumed that it was the front seal... but it looks to be overfilled to a bit, so i was just curious. Thanks for the help!
I normally fill a 4l60e to the full hot on the stick when it is cold. With that being said I do not believe that your trans is over filled. I would suspect that when you installed it if you prefilled it, that some might have got in the bell when you installed it. Brake clean the out of it and see if it continues to leak. The other thing to consider is if possibly you cut the pump to converter seal or if the converter has a pin hole in it. Chasing a leak can be a PITA but do a thourow a job and you will find it. Vince
My comment is specific to the 4l60e. You are correct on the 3 speed transmissions especially the th400. I have always found that the 4l60e is not fussy with a little extra in there. Unless it is way over filled I have not seen this issue in a 4l60e. If you do see oil blowing out in the vent on a 60 there are other internal issues or an issue with the converter building pressure and releasing it into the transmission. Good question. Vince
buddy of mines lt1 car spit 3 of them out, but he was super hard on it.
i was with him twice when it went.
both times had to limp home, only 3nd gear left in the trans with a small cloud of "blown headgasket syndrome" behind us.
im sure there have been cases where a seal will get ripped by a rough hub, or a pan gasket that has had enough, but its very uncommon, IMO.
you can leak fluid from florida to california. as long as its at the proper level, you arent going to hurt the tranny.
if it gets low and not filled, then youre going to have an issue.
do you have an aluminum pan on it?
what pan gasket do you use?
Hey thanks for the reply and yes I have a gasket on the tranny... it is the one that came with the filter when i changed it. It came from autozone... nothing fancy. Why do you ask? you think i should of ran something different or sealed it with RTV or something?
I personally do not like silicone on a pan with a gasket. I would definitely keep an eye on the fluid level until you get it figured out.
I was thinking this morning about your leak. It is possible that your pump to case seal might be leaking. On the later model units there is a metal clad type seal that do leak from time to time. If you have the front of this unit resealed make sure that this seal is replaced. To replace this seal the bell housing has to be removed.
if so, i would capture the fluid and change out that gasket.
i have had nothing but trouble out of those cheap parts store kits.
i prefer to buy a filter and gasket separate. its more cash, but worth every penny.
most of the time, you get a cheap rubber gasket that will stretch like a rubber band just hand tightening the bolts.
dont have the part # offhand, but felpro has a nice gasket thats fiber, no stretch there.
i will smear a very thin layer of rtv on the pan side(and i mean thin) just to keep the gasket in place till i can get the bolts started.
much easier to clean off the pan than it is the transmission rail the next time you change the fluid/filter.
thanks a lot for the help guys. right now im talkin to some guys near jax florida about replacing the seal for me. i might get them to do some upgrades to the tranny while there at it. i was thinkin an hd2 shiftkit and someone reccommended a shell or something? whats some good stuff to do to make it stronger while their in there? they are efi alchemy btw.
