T-56 to TH400 swap need a converter
Old 01-21-2010, 06:54 PM
dschmittie1's Avatar
Default T-56 to TH400 swap need a converter
Alright so here is the low down. My car is a Procharged 347 ls1 made 687rwhp and 590 rwtq through my t-56 last year. I am making a swap to a TH400 with a Trans brake. I am also making some changes to the motor by changing heads, cam and intake. Probably gonna leave the pulley size where it is at for now but I will probably change that by the end of the season this year.
The car is a 50/50 Street Strip car. And went 10.33@136mph with a 1.61 60'
The car makes Peak torque around 5200 rpm. Makes 500rwtq by 4200 rpm and torque and horsepower curves cross around 5200 rpm. I know things will change with the new setup but I think things will be fairly similar.
Looking for what convertor and Stall size I should go with.
Old 01-24-2010, 01:08 PM
I think I am gonna pick up a 9" 3800 ATI stall from a buddy of mine that was originally for a Turbo car and has low miles. Should preform well for now and I can get it restalled if I need
Old 01-24-2010, 05:01 PM
Originally Posted by jim1450
Sounds like a good move, you can call them with the# off it & they can look it up. My car came from Bel Air, MD & I remember driving through York going there so I assume they are pretty close to you plus they make a real good converter from what people that have them tell me.
yeah about 45min to an hour away. I know I can call with the serial number. I know it does have the antibalooning plates and stuff too. He said he would give me the serial number to call and confirm if I wanted.
Old 01-25-2010, 07:05 AM
LS1Tech Sponsor
FTICONVERTERS's Avatar
give us a call and we will spec one out for you.
Greg
FTI competition converters
1-866-726-8358
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 01-25-2010, 08:31 PM
cabech984's Avatar
I have a PI Vigilante 4400 Stall Converter for the Th400/LSx setup. It has 300 miles on it and comes with one free re-stall. I'm selling because I'm converting to a built 4L60E. PM me if interested
Chris
Old 01-26-2010, 05:54 AM
White.Lightning's Avatar
Your car is gonna be a beast when you swap the 400 in!
