No speedometer,odometer or trip
If you replaced the VSS it is probably the cluster. I just had to replace mine. If you have HPTuners or something and can scan, if the scanner reads MPH then the VSS and PCM are reading it implying that the cluster is not displaying it. The MPH and ODO are interconnected.
