99 Trans 4L60E won't go into gear
Old 01-26-2010, 07:08 PM
neodin78's Avatar
Default 99 Trans 4L60E won't go into gear
I recently swapped an LS376/480 crate engine into a 1999 Trans Am. I had the transmission rebuilt by a local shop with a dacco 2500 stall converter, beast shell, and 5 planet gear trains. When I put the converter on the shaft, it went back, then I rotated it and it went back further. I think I installed it correctly, because the transmission bolted to the engine, and the converter bolted to the flex plate no problem. I filled the transmission with 6 quarts of fluid. When I started the engine, and tried to put the transmission into gear, the tires wouldn't turn. None of the gears work. It's like the car is still in neutral. I have no idea what is going on, and I was wondering if anyone else had ever experienced a problem like this.....thanks
Old 02-03-2010, 07:03 AM
vortecyota's Avatar
a dry 4l60e will hold 11-12.5 quarts depending on converter and cooler size.
Old 02-03-2010, 08:55 AM
witry's Avatar
did you hook up the shifter?
Old 02-03-2010, 08:57 AM
witry's Avatar
and yea a dry 4l60e holds alot more then 6.... more like 10-12 i think, 6 is just like a pan drop and filter swap
Old 02-03-2010, 09:29 AM
LS1Tech Sponsor
performabuilt's Avatar
You need alot more than 6 quarts of fluid first then go from there.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Quick Reply: 99 Trans 4L60E won't go into gear
