Cant Get Bellhousing Bolts
I have the transmission out of the car and all I need to do is get the bellhousing off to put on my performabuilt trans. I have the correct T-50 bit they just wont break loose. I have hit them with the impact and heat from a torch with no luck any idea's?
The crappy thing is that I only really need the bolts as I have a spare bellhousing.
I have the socket and tried it with a breaker bar. One cheaper bit broke so I returned it and got a stronger one. It is tough to keep it seated correctly on the bolts without stripping the T-50.
I seem to be making a bit of progress. just got 2 of them out. had to have someone else hold the T-50 on the screw as hard as possible and go slow with the breaker. I'm just praying the bit doesnt break every attempt I make!
