will th350 fit lq4
Old 02-05-2010, 11:43 AM
nerveink's Avatar
Default will th350 fit lq4
hello.
sorry if this question has been answered but i just wanted to know if a th350 will work well with a lq4.
im not going to be doing any racing or putting nitro or anything like that.
i spent 800 bucks getting it rebuilt and id hate to see it go since it is basically new.
any help would be much appreciated!
Old 02-05-2010, 01:40 PM
forcd ind's Avatar
sure, just use the 4l80e flywheel setup(.400 spacer, flat flywheel), and the stock 350 converter
Old 02-06-2010, 03:41 PM
Taubr Unit's Avatar
everything u need to know in here...
https://ls1tech.com/forums/automatic...-what-use.html
just did this swap in my car a week ago, its simple
Old 02-07-2010, 02:25 PM
Paul57's Avatar
Here is a kit for that... http://advanceadapters.com/product/3741/712500A.html
It is available at Summit...and other places (I suspect).
Old 02-07-2010, 03:58 PM
remauto1187's Avatar
All th350,th400,700r4/4L60/80/85 tranmsissions will bolt right up to ANY chevy v8. (assuming it is not a Buick/olds/pontiac) transmission.
Some applications require mix and match of spacers, convertor, bolt on tranny bellhousing and/or flywheel.
Quick Reply: will th350 fit lq4
