4l80e shifters
Old 02-10-2010, 11:15 PM
StrokerTA's Avatar
Default 4l80e shifters
Who offers a good shifter for a 4 speed trans?
Old 02-11-2010, 06:48 AM
forcd ind's Avatar
i use the B & M pro rachet, can be used either 3 or 4 sp, some people dont like it because you have to rachet it twice out of/into park, but no big deal
i have used several of these, i like them because the stick stays in the same place, doesnt end up way forward in park, important in this case because i have a bench seat
Old 02-11-2010, 08:46 AM
Gingervitis Addict
slow67's Avatar
Only problem is most ratchet shifters dont have the proper spacing for 4L80Es. I will have to make a custom bracket for the selector shaft for my quicksilver (for now its lined up in OD and D and thats all I use).
Old 02-11-2010, 09:13 AM
StrokerTA's Avatar
What about racing a 4l80e, are you guys manually shifting? or just letting it ride in drive?
My application is a conversion project, I am thinking about just modifying the stock shifter. Because I HATE ratchet shifters.
Old 02-11-2010, 09:38 AM
BoostnTBSS's Avatar
tci makes a nice one setup for the 4l80e....
Old 02-11-2010, 01:09 PM
forcd ind's Avatar
my rachet works perfect with the 4l80e trans, i orig had a 400, then pulled the pin to use with the 4l80e-i have the Compushift controller, i might oneday play with setting it up to shift at a set RPM, see how it works
right now its great for banging gears-personal pref, like everything else
Old 02-11-2010, 08:53 PM
4bangermustang's Avatar
I use the stock shifter.
When racing mine, the T-Brake only works in Drive(it might also work in one or two, not sure). My computer controls my shifts.
Hard to out perform the computer......
Old 02-13-2010, 09:40 PM
rcsfastmonte's Avatar
B&M makes a 4 speed auto shifter called a hammer,I had one worked great looked great as well in car.
Old 02-14-2010, 09:14 AM
tals7's Avatar
Smile
we use the tci controler with the 4l85e.just leave it in d and go.all shifting is done by controller(which you can program).when the controller see,s wot it goes into wot mode and only shifts/locks up when you tell it to
other wise the shifting/lock up is based off tps,rpm,mph all of which you will have full control of.imo it is simplest way to go.
Old 02-15-2010, 09:15 PM
I use the Bauman controler,way cheaper then the others does the same thing,I have the stock shifter in my car, looks stock,its all auto,works great with the performabuilt 4l80E.
Quick Reply: 4l80e shifters
